**Help** Basic commands to check faults Cisco Switch
scoobs
Guys
Hey can someone help me, I need to check if any component of a cisco switch is faulty, Could you help me with some
basic commands to check ? and maybe advise what I should be looking at if something is wrong
Thank you
scoobs
does this look right ?
Sh log
show environment alarm
show environment status power-supply 1
show environment status power-supply 2
show power status power-supply 1
show power status power-supply 2
show environment temperature
show environment connector
show ip ospf nei
show ip pim nei
show route sum
Best command is
show env all
this will list all sensors and also if they have failed/reached thresholds.
You can also do a sh log and look for failures such as %FANFAILURE%
Best command is
show env all
thank you so much for the advise dude appreciate it man
