Help - Billion 7202GR2 wireless stopped working
linkinpark
My wireless connection for my billion router has gone crazy since last week. ANy pc's that try to connect to it cant be assigned an ip. When i try to manually assign an ip, it says connected but i cant do anything with the network. When its auto assigned by the dhcp, it just saying acquiring network address. It just stoppped working all of a sudden, i didnt change a thing. It stopped working on both my wireless on pc and my laptop, so it has to be the router.
I checked the router settings and everything seems to be fine, its in bridge mode and the dhcp server is running, the wireless log shows the mac address of the connecting pc, but the ip is unknown, and then it keeps on disseppearing and coming back.
Can anyone help please??
Thanks.
Had a lot of problems with that same router, got it replaced, still nothing, and then got sent the latest update for my wireless drivers from the tech support, and that helped. It works a lot better now.
Definitely get hold of the technical support guys, they're very helpful :)
