Help - change country code on Samsung 50UHD7000
SlowInternet
Heidelberg
I need assistance please. How do I change the country setup on this tv with this small little remote. Need to change for Netflix.
Edit : Solved. Everything working fine now.
Hi
I have the same tv and after changing my country and network settings (got unotelly as a provider), it still says netflix is not supported yet when i try download it. Couls you please assist if you had the same problem and solved it. i use a wifi as well.
To change the region for the H series use:
Select TV as source
Press Menu on the remote
Select System
Select Setup (If you are unable to enter Setup go to Support > Self Diagnosis > Reset)
Continue the set up
Stop the setup when you come to the Smart Hub Terms & Conditions, Privacy Policy page and position yourself on the " I accept the general conditions blah blah blah field" where you have to tick the box
Press the following sequence on your remote
MUTE - RETURN - VOL+ - CHAN + - MUTE
Select the country you wish to receive apps from.
Once you have selected the country let the setup complete
Worked for me
