help choose media player
I.am.Sam
In your mind ...rent free
Hi guys
i want to buy a media player but just for basic series and movies..nothing to hectic and expensive and without a hdd
my budget is around r600 and my choices are the isonic a3hd , ac ryan mini (i think) and the apacer al670
it must have hdmi and atleast a good look and feel
and also i dont want to scan through millions of files to get one , it should be able to read the file set up like how i see it on pc cos i have seen some guys talking about 1 folder with all files
and if anyone knows anyone who has them for cheap in cpt please do let me know
You just missed Esquire's Scary Hour Sale : AC Ryan Essential for R399 excl VAT
The Apacer AL670 has been discontinued leaving only the AL720. You could probably pickup Mecer MP1055 for less than R600. Have used it myself and you can throw almost any type of file at it and it plays them all.
I have used the iSonic and sold several of them. Works very well, didnt have any problems and the GUI for finding files is just like a PC, i would recommend it though i haven't used any of the others.
cos the isonic one is aroud 480 and yeah i wanted to find out about the gui ....cos dont want something thats hard to use cos parents will most likely be using it most of the time and also you can add a 2.5drive in it ....
does it play most of the files tho and can it handle up to 2tb and any format , ntfs or fat32
tnx for the help
