my computers corrupt - lt alwys seems too be busy - even when I'm not running anything. My task manager shows some programs I donot recognise. e.g flec003.exe, facegame.exe. does anyone know what these are and what they do. How do I get rid of them as when I try to end process it tells me acess denied.
flec003.exe - DANGEROUS Flec003.exe is a Troj/Bancban-QH
Related files:
%System%\flec003.exe
%System%\hldrrr.exe
%Temp%\258a5.dmp
%Temp%\WER1.tmp.dir00\appcompat.txt
%Temp%\wer1.tmp
Kill the process flec003.exe and remove flec003.exe from Windows startup using RegRun Reanimator - http://www.regrun.com
Removal: flec003.exe is removed by RegRun.
facegame.exe - DANGEROUS
We suggest you to remove Facegame.exe from your computer as soon as possible.
Facegame.exe is a Troj/Agent-ICM.
Kill the process Facegame.exe and remove Facegame.exe from Windows startup.
Removal: facegame.exe is removed by RegRun.
Remember to disconnect your network or modem cable from your computer. Restart your computer in Safe Mode (press F8 during POST). Run Reanimator.
I can e-mail you RegRun Reanimator if needed - not sure where to dump the file locally?
