Hossie
I need some help, I've set up XP Home using the Broadband "Username & Password" After trying to connect it freezes Mouse KBD and need a reboot.
LAN with 7 PC's is working ISP is Telkom other machines work and connect
to Telkom ADSL never more then 2 PC's are connected. So, it cannot be the Hardware since the Lan works another XP machine on the same connection also works. It can then only be a Software problem, but it's the first time it happened to me the system is preinstalled from the supplier ?
Anybody out has got a solution or experienced a similiar problem.?
