Seriously
- Nov 29, 2012
My son at varsity is having to do some assignments. The software code compiles and works where the outputs seems to be as prescribed by the project administrator but there seems to be issues experienced by many students. Fitchfork is constantly giving the assignments 0 or - results. He is not the only one battling as on the group there are many with the same problems. Some students get 10/10 by creating a "infinite loop" in some sections of the code but that could maybe efffect other sections of the assignment later and coding for a similar result still gives 0/100. He is running out of submitting slots. The DR "Moderator" or lecturer on the group say that their problems could be different outputs and they must the the tech department to view the outputs required then they will see where they are wrong but that can only happen on Monday and there are many modules still to complete.
The only feedback form Fitchfork he got was "exit code2"
Any advice or help would be appreciated.
