D
Deleted member 148173
Guest
Made a phone call to the call centre to find out if there's a problem with my line as of recently, I've been having slow connections speeds that crawl like a snail and sometimes perking up now and then.
The person at the call centre checked and said that my modem isn't syncing with the exchange. What does that mean? My stupid boyfriend doesn't ask what that means and I was wondering if it could be due to the DNS that needs to be set correctly on my network card so I asked him to ask the person (as he had put the person on hold to ask me questions for the person) to please ask the guy to give me 2 IP addresses for the DNS server. I was peeved off because the boyfriend wouldn't listen and didn't ask, thinking he's mighty clever when he told me he really knows nothing about ADSL, him being a retired telkom employee due to disability. I can't believe he wasn't trained to learn more about ADSL and I've had to try and get hold of his brother who knows much more but no luck...
So can someone explain to me why the person at the call centre said my modem isn't syncing with the exchange and that he can't see me being connected at all?
Here are the details:
ADSL line: 1024 with Telkom
ISP: Axxess Uncapped 1024 Express Plus
Statistics:
Speedtest and Pingtest keep on failing to load. I can't even run either one.
I did lodge a ticket with Axxess to find out what's going on. The guy asked me to add the primary and secondary DNS - had this issue last night and still has the issue today all day, only worst starting at around 10 or 11am, with pages taking too long to load and sometimes the pages just loading like a stuck record.
Only weird thing is I find that I can play Heroes of Newerth online without any lag issues. Makes me wonder what the heck is going on...
Line Rate - Upstream (Kbps): 512
Line Rate - Downstream (Kbps): 1024
Statistics:
Statistics -- ADSL
Mode: G.DMT
Type: Fast
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 22.8 12.0
Attenuation (dB): 33.0 14.0
Output Power (dBm): 7.1 7.6
Attainable Rate (Kbps): 8128 948
Rate (Kbps): 1024 512
K (number of bytes in DMT frame): 33 17
R (number of check bytes in RS code word): 0 0
S (RS code word size in DMT frame): 1 1
D (interleaver depth): 1 1
Delay (msec): 0 0
Super Frames: 534008 533951
Super Frame Errors: 0 0
RS Words: 0 0
RS Correctable Errors: 0 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 21924629 0
Data Cells: 1078512 0
Bit Errors: 0 0
Total ES: 0 0
Total SES: 0 0
Total UAS: 9 0
