Mal1ce
Hoping for some wisdom from some more experienced AD/DNS folks here on here.
My users with laptops are getting two A records in the forward DNS zone, one for their wireless cards and one for wired. They only get a single PTR record in the reverse DNS zone.
What appears to be happening is users are working at home, hibernating their notebooks, then coming into the office the next morning and opening the screen before plugging in their network cable.
As a result, the machine automatically connects to the wireless network first, gets an IP and DHCP registers an A record. Then when the network cable is plugged in, the machine gets another IP and DHCP registers another A record. DHCP seems to update the PTR record.
This is wreaking havoc with the Konica Minolta scan-to-PC FTP utility or connecting to these machines via hostname as I keep querying and getting the IP assigned to the wireless card from DNS and not the one assigned to the cabled Ethernet adapter.
i've configured an user account for DHCP with strong password, set DHCP to run using those credentials, added the DHCP server (which is also the DC) to the DnsUpdateProxy group & secured it and set DHCP to update everything.
How can I go about forcing DHCP to instead update the A record rather than register a second one when the laptops swap from wireless to wired?
Any advice appreciated!
