Thugscub Executive Member Joined Dec 3, 2008 Messages 8,236 Reaction score 7,207 Location Lost Dec 14, 2008 #1 I tried to install a sata dvd into my pc, it did not work. Then went back to my ide dvd rw. it gives error, insert cd. The light comes on but it is not reading the cd.
N Nameite Expert Member Joined Oct 19, 2005 Messages 2,227 Reaction score 0 Location Joburg - Honeydew Dec 14, 2008 #2 Did it pick any of it up in the Bios?
Thugscub Executive Member Joined Dec 3, 2008 Messages 8,236 Reaction score 7,207 Location Lost Dec 14, 2008 #3 Hi Nameite Sorry about the delay Escom did its trick again.Yes it does pick it up in Bios.It does not spin up. im using Xp
N Nameite Expert Member Joined Oct 19, 2005 Messages 2,227 Reaction score 0 Location Joburg - Honeydew Dec 14, 2008 #4 It might have been damaged when you swapped it, though not very likely. See if you can take it to another pc and see if it works. You told me you ipdated the bios, was it before or after swapping the drives?
Thugscub Executive Member Joined Dec 3, 2008 Messages 8,236 Reaction score 7,207 Location Lost Dec 14, 2008 #5 That was after swaping the drives when it did not work, I fitted it to a Giga Byte 800 m/board. XP could not boot just a bluescreen of death for a split second then the pc starts booting over and over. All the other drives are ide. i think your plan of taking it to another pc is the best idea. Looks like im going to have get another ide dvd unit if that does not work, it will probably work out cheaper rather than taking it in for repairs. Thanks for your input much apreciated Last edited: Dec 14, 2008
N Nameite Expert Member Joined Oct 19, 2005 Messages 2,227 Reaction score 0 Location Joburg - Honeydew Dec 15, 2008 #6 No prob, sorry I couldnt be much help though Also try swapping the IDE cables...that use to work for me
