[HELP} Fill Jet REfill Kit
UltimateWarez
Kwa-Zulu Natal
Hi
I bought a fill-jet refill kit from glomail.
I mistakely damaged the cd with the intructions...
i got a HP 131 cartride...does anyone know where i must make the whole to put the ink in cause i cannot see any hole on the cartridge?
please help
thanks
well if it says "make a hole" then that means there ISN"T one to begin with.
ink cartridge manufactures won't make it easy 4 u to refill, hence why you probably got some sort of a injection thingamajig with...?
found a hole already on there..
seems to be working nicely...ink quality is pretty good.
