Help finding a VOIP product
BearCruz
PTA
Hi All,
Im hoping someone here can suggest a product and provider for me.
I run a small one man business (being myself). I am looking for a product that will help me with the following:
- lower costs of calling out (hence the VOIP)
- allow me to make calls over internet (hence the VOIP)
- need a 'single number/ line'
- need to be able to use this with my iPhone 13 (I assume through an app)
- needs to reflect on the other persons side as my number (see below)
I am currently using a Skype number for this, but the issues I face are the following:
- Dialling out is an absolutle hit or miss. While it seems to be ringing on the other persons side, it does not.
- The number the other person sees is completely random and sometimes shows up as 'scam' or the such on their true caller
Obviously this is not good for my business.
While I would like to use Afrihost's VOIP product, I feel that it is quite expensive. Tell me if I'm wrong.
I would appreciate any help/ guidance.
Thanks.
I am probably going to be crucified for this, but have you tried Vox Voip. R 171 pm (unlimited calls to local/cell phones). Currently using it for our office setup over 3CX and works fine.
Thanks will give them a look.
We using 3CX as well at the office and it works great
