Hi,
I am going to be upgrading my PC soon and need some advice on what new power supply to get as I'll be upgrading my graphics card and not sure how much power it needs and my total system usage.
System Specs currently:-
Pentium D 930 3.0GHz
768MB DDR2-533 RAM
ATI Radeon 9550
1 SATA HDD
1 IDE HDD
1 DVD Writer
1 DVD ROM
Sound Blaster Live PCI card
At the moment I have an AOpen 400W PSU.
Using the eXtreme Power Supply Calculator it states that I'm using around 275W of power. If change the video card from 9550 to X1950 Pro the total goes up to 323W. So looks like the X1950 Pro uses up about 48W of power (I've heard high on other sites).
Now I want to upgrade the graphics card to a ATI Radeon X1950 Pro AGP. I've been doing alot of research and found alot of people warning to make sure that your PSU can handle 30A on the 12V rail to run the X1950 Pro card. This is also recommended by a manufacturer to have 30A on the 12V rail. And another website states that "Just make sure you have a 450w power supply or better (18a on the 12v rail at the minimum.)". So I'm not sure which one to believe - 18A or 30A?
Looking at the specs of my current PSU (see link), it looks like it doesn't support even close to 18A or even 30A. So I guess I need a new PSU right?
Can anyone recommend a PSU that will support my new video card?
The closest and cheapest match I've found is the CoolerMaster Extreme Power 650W PSU. This PSU has 18A on each 12V rail, but will that be good enough since one of the manufacturers and a few people mentioning (here and here) that it is recommended for 30A on the 12V rail. I'm not even sure if 650W PSU is overkill for the system in general, since at the moment it's only using 275W. And I'd rather have a PSU between 450W and 550W, but cannot find one that supports 18A on the 12V rail as a MINIMUM.
I wouldn't want to get this new graphics card and it doesn't even work in my system at all.
Please any help guy on this matter? This whole AMPS on the RAILS thing is completely new to me, and luckily I've done a bit of research before I went ahead and bought it.
Thanks!
768MB DDR2-533 RAM
ATI Radeon 9550
1 SATA HDD
1 IDE HDD
1 DVD Writer
1 DVD ROM
Thanks!
