Hey guys!
Long story begins:
So I currently have a Drobo 4-bay enclosure which serves 3 purposes:
1) Holds all my backups of my mac
2) Holds all my movies & tv shoes
3) Has redundancy incase a hard drive fails
I currently have it connected to my mac where Plex serves the content from the Drobo to my Apple TV from where i watch all my tv shows and movies.
Because the Drobo does not have an ethernet port, I am forced to have it connected to my mac via usb all the time which annoys me because I would like it to be in a different room where my router is. I have tried connecting the drive to an old netbook which was loaded with ubuntu and contected to the router and share the content of the drive via a Samba share, but this was extremely unstable and my Time Machine backups would not work over a samba share. I then went and bought a router with a usb port on it to share the content, but this was not compatible with the HFS+ file system i had on there and my time machine couldnt back up to it either when I used NTFS.
So anyway, I have looked at off the shelf NAS drives, but because I want to have Plex media server installed on the solution to transcode files for streaming, it needs to have a relatively powerful CPU (I would think at least 2ghz), which off the shelf nas drives do not have.
So this is why I would like to build my own Raid/NAS server type of solution. I would prefer a small solution, such as an HP Proliant N40L, but with a more powerful CPU. I would need space for 4 3.5" drives. Budget is about R4000 excluding the drives.
What would you chose?! And what OS would you use? I was thinking of FreeNAS or unRAID or something that supports Plex.
Long story begins:
