phly
- Mar 13, 2013
Hi all,* I need help in deciding my next laptop. I formerly had a core i7 dell xps laptop and it served me well. It had all the features I would need. I now want to invest in a new more capable but lighter and more portable laptop. I have narrowed my choices down to a MacBook 13inch probably won't be retina and Dell xps 13 but other suggestions are welcomed. Also I don't mind considering a sale on Gumtree or a used but still in great condition laptop.
I'm a graphic designer so the laptop should be able to breeze through adobe suite and also be able to do video rendering to a certain extent. IPS display, a core i7, dedicated graphics card and backlit keyboard are my main lookout points. Bright screen since I will be looking at it. Working late nights hence backlit keyboard. Dedicated graphics for premiere and after effects renders. Long battery life will be a huge plus. Portable yet formidable.
The problem here is some suggest a MacBook 13inch will be perfect. No dedicated graphics card but if I can score a retina one I won't regret it as long as it's a core i7 one. On the other hand the Dell xps or similar powerful laptop will be more powerful than a mac or so I'm told. Dedicated graphics card will assist the core i7 in renders etc tremendously.
Size wise, Will a 13inch Mac or Windows laptop be decent enough for design? The Dell xps was a 16 inch with bright screen backlit keyboard, dedicated graphics card with 1gb ram. I'm primarily into graphics so video is just something I want to get into as time proceeds. I travel daily so a portable light laptop would be a plus.
Stick to Windows or take the plunge to Mac ? If windows which laptop and if Mac,* even though this is not a mac forum,* 13inch or 15inch. Or must I aim for the 15inch with dedicated graphics card and not any lower? Just need to know what would be ideal for my needs and I take it with the experts here I cannot go wrong. Budget is only 7k.
