Help me set up 2 connections
///MoH
Durbz
Hey guys... need your help
Got my local acc now need 2 set up route sentry
Using a mega100wr2... wer that bridgemode option ?:confused:
So come come do tell :D
newshost awaits :p
so much 4 the help:p
anyway did most of it but now... wer do i find this :
Important: You must set the number of lines (WAN endpoints) in the PPPOE protocol properties to 2 or more otherwise you will get an error that the device is busy when you try to “dial” the second connection. When testing the connection for the first time you must select the ‘save password’ option on the “Connect” dialog, otherwise Route Sentry won’t be able to automatically connect for you.
come guys
Nevamind... done :D
Hey
You made 2 bridged connections?
Or one bridged and one on the router?
Dan
Search the forums, there's enough info
and it looks like the 100wr comes standard in halfbridge mode, i connect with one on the router and one ppoe and didn't change any settings...
