kenl
Hi all,
I composed a survey for people who has/had/going to have ADSL conection. It is for academic use, if you guys don't mind, please help me to complete the survey. (I am sorry but I can't afford to give a reward tho...)
1, Are you from an IT related background?
2, What is the purpose of your ADSL line? (business, download, browse, gaming, etc)
3, What brand/model adsl modem/router do you use.
4, Describe your (home) network (ie, 2xpc plug to the switch, which plug to the modem/router, etc)
5, What do you think each item in your network (modrm/router, switch, access point, etc) does?
6, Have you ever worry about your network setup? (say if something gone wrong, or if you get a new machine to plug into the
network, etc)
7, Is the setup interface for your modem/router self-explained?
8, Is the setup information from the modem/router manual and ISP manual sufficient for you to setup your ADSL connection?
9, How did you get your ADSL network set up?
10, Was there any help needed when you setup your ADSL router/modem? (incl. Telkom technician) what level of help was
required?
11, Do you think you can change modem/router setting on your own?
12, Have you looked at the modem/router settings?
13, In detail, describe what you need to do to setup your ADSL modem/router from fresh (say you lost all the settings).
thanks in advance.
network, etc)
required?
thanks in advance.
