SauRoNZA
I disagree totally.
I assume you are stuck on the original uber low quality Pro Logic that coded 4.0 sound across stereo. You can call it surround if you want but I call it duplicated stereo and it hardly ever had any traction in the wild.
So sure it’s possible technically, but it’s not happening in this context.
More likely is that Pro Logic 2 is faking stereo into surround with the dynamic algorithm which makes OP think it’s surround (from the source) but it’s just stereo bullshitted across 5 speakers and usually turns the centre channel to mud which would explain why he can’t hear anyth8ng.
Source ?
That R and W are analogue signals - how does it change to digital? A coax cable isn’t compatible with analogue anyway ? It’s difference impedance
Coax is simply a mono cable, and then transmits a digitally encoded stream instead of playing an analog L/R one.
No special impedance or anything required.
You can take any of these crappy boxed with a unit cables and just use one side for coax and test it yourself. The connector is the same.
There’s no such thing as an analog or digital cable, the device determines if it sends an analog or digital signal based on the port the wire is connected to.
You could use a coat hanger if you could make it connect and it would work just fine.
