Help needed,packet loss when smart tv is on
ViciousClone
Western Cape
Hi all
So i have 10mb adsl,got a new samsung series 7 smart tv
When the tv is off i logged into teamspeak with no packet loss.Turning it on boom around 2-10% packet loss .
Note this is when watching netflix.
Any advice or idea why?
Hey,
Do you have an android phone at hand? Could you install this app: Wifi Analyzer.https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en
Can you give an image of all of the screens, before and after turning the TV on and off? Be sure to use the Time graph over a minute.
Just as a starting point.
EDIT: Also a diagram of floor plan if you would and environment.
Hi all
The TV does not support speeds of 10Mbps or lower and it needs Cat7 cables if wired.
Maybe that is the problem?
Screen mirror and/or Smart view along with TV Cast via Android. Not sure about other OS.
Post the fix and then leave it, to help others who might have the same issue.
It does not have a fix,thought it was the tv but it seems anything that just touches bandwith spikes the ping and packet loss.
Will test axxess ans crystal web tonight to see what happens
Crystal Web
Zertop's LineTool Results
Date/Time: Tue Nov 22 19:31:29 CAT 2016
Basic Report:
Your packet loss was 3%.
Your average ping was 12ms.
Your maximum ping was 19ms.
You seem to have some packet loss. This indicates an issue on the line.
Looking at your average ping, your line seems to be running perfectly.
It seems that your maximum ping is also good. If there are any issues, they most probably lie with your ISP
Detailed Report:
Pinging 155.239.255.250 with 32 bytes of data:
Reply from 155.239.255.250: bytes=32 time=12ms TTL=63
Reply from 155.239.255.250: bytes=32 time=11ms TTL=63
Reply from 155.239.255.250: bytes=32 time=19ms TTL=63
Request timed out.
Ping statistics for 155.239.255.250:
Packets: Sent = 30, Received = 29, Lost = 1 (3% loss),
Approximate round trip times in milli-seconds:
Minimum = 11ms, Maximum = 19ms, Average = 12ms
Axxess
Date/Time: Tue Nov 22 19:27:03 CAT 2016
Basic Report:
Your packet loss was 0%.
Your maximum ping was 13ms.
Detailed Report:
Reply from 155.239.255.250: bytes=32 time=13ms TTL=63
Packets: Sent = 30, Received = 30, Lost = 0 (0% loss),
Minimum = 11ms, Maximum = 13ms, Average = 12ms
Vox Telecom
Date/Time: Tue Nov 22 19:24:48 CAT 2016
Basic Report:
Your average ping was 11ms.
Your maximum ping was 12ms.
Detailed Report:
Minimum = 11ms, Maximum = 12ms, Average = 11ms
