I am Penguin
- Jan 26, 2009
From my post here http://mybroadband.co.za/vb/showthread.php?p=3068106#post3068106
I felt I should rather ask the question here too.
This is what is specified by Tuks
I presume this in RED is what she will need? . Any advice?
The aim is to code, practise, compile and run her exercises when/if she have time, on the same platform as the varsity.
Questions:
Which Distro is recommended
There is now a stable KDE4.3 would that suffice
Must we use the GCC4.3.3 compiler
Where can I download the Linux distro and GNU from locally.
How do I set up Dualboot Linux/XP or Win7
I presume so, but would the actual coded program remain the same if coded on on Visual Studio, Visual C++, "Intel® C++ Compiler Professional Edition for Linux" and then just recompiled on GCC 4.3.3?
Any help to get me going on Linux/C++ FAST will be appreciated.
The platform that you have to use is Linux, and all programming assignments will be marked on a Linux platform. You have to make sure that your programs run on Linux. If not, then your programs will not be evaluated.
3. The programming language used for COS110 is C++. All programming assignments must be implemented using C++.
4. Please note that all programming assignments will be marked using scripts. This means that you have to follow the instructions of the assignments very carefully. If you deviate from the specifications of the assignment, then the scripts will not be able to mark your programs, in which case you will get zero, or a very low mark.
5. Note that all code must run successfully on the environment as provided in the Informatorium. Debian with KDE 3.5 is loaded on the machines in the Informatorium. The version of the GCC compiler used is 4.3.3.
Questions:
