help on harddrive
Flame
Hi
My 2nd harddrive seems to auto shut down and start up. Is this good for a harddrive? Where do i set this setting in win7, cause its starnge it does this, cause i never setted this.
I know in winxp u can set this, but where in win7? I cant find where.
Thanks in advance
Hi
Thanks in advance
If it's an internal: Use the windows port of hdparm.
If it's external: Use hddcoffee
control panel power options, i use high performance then click change plan
click change advanced settings, hard drive, i select never turn off hard drive
