Help please - advice re generator
CoralB
Hi guys, can you please advise me. We just bought a 2.5 Kva generator as I work from home and need to keep my laptop powered up during loadshedding. We plan to also connect the TV and maybe a light if the power is off in the evening. Is it ok to run my laptop off the generator?
I don't see any reason not to, but just to be safe you can connect it through a ups.
Your laptop works on direct current, whatever happens with the output from the generator will affect the part that works on AC, which is your charger.
