Help please - possible malware ?
I've seen some addons do this - malicious ones though
Hello ,
I recently started noticing these underlined links on different pages when I browse. They are hyperlinks to a Website called http://www.dating.co.za , at first I thought someone hacked http://mybroadband.co.za as I saw it here for the first time but then I noticed its on every website I go to. Any advice please.
Antivirus programs such as Kaspersky Internet Security will be able to detect and remove these kinds of malicious malware. If you don't have a tool that can remove it automatically, you can use a tool Autoruns (http://download.sysinternals.com/files/Autoruns.zip) and have a look at the Internet Explorer tab to see any dubious extentions, and remove them.
If you are familiar with setting the boot order from the bios I recommend you download This
What is it?
Windows Defender Offline can help remove such hard to find malicious and potentially unwanted programs using definitions that recognize threats. Definitions are files that provide an encyclopedia of potential software threats. Because new threats appear daily, it's important to always have the most up-to-date definitions installed in Windows Defender Offline. Armed with definition files, Windows Defender Offline can detect malicious and potentially unwanted software, and then notify you of the risks.
To use Windows Defender Offline, you need to follow four basic steps:
Download Windows Defender Offline and create a CD, DVD, or USB flash drive.
Restart your PC using the Windows Defender Offline media.
Scan your PC for malicious and other potentially unwanted software.
Remove any malware that is found from your PC.
It's a very good free Anti-malware product from Microsoft.
