Help..Recommend Halfbride/PPTP VPN router? Help
Zyzzyva
HI,
My mega105 telkom router has decided to die on me. It's 13 months old, so no gaurantee for me. SO instead of going through another telkom router, as i've had several, could you guys point me to a good router which has halfbridge and potentially PPTP VPN (if i decide to go with the openwebs vpn service.)
If the PPTP VPN functionality makes it too expensive, then halfbridge is a must. It has to work with route sentry.
Any ideas?
Cheaper is better as i seem to go through one of these every 2 years. If the option are too expensive then i'll just go for another telkom one. What do they cost now?
P.s. Eish i'm using my phone as my internet connection, i miss my adsl.
Lol the two helps in the thread title was maybe a bit much
