MrMikey
I have a laptop that is currently running Vista Home Premium as an OS and I want to install Window 7 Ultimate on it. The laptop has 1x 160 Gig drive which is partitioned as follows:
1. 10GB EISA Configuration
2. C Drive 60GB NTFS (system,boot,page file,active,crash dump,Primary
partition)
3. D Drive 60GB NTFS (Primary Partition)
4. G Drive 20GB NTFS (Logical Drive)
5. 9.77GB Unallocated.
What I would like to know is, how should I go about "cleaning up" this h/drive? I have backed up all the data I require to an external source so I would like to wipe the entire drive clean if I can.
Does the EISA configuration contain data relating to my existing installaion and can I safely delete it?
I would appreciate your help, comments and assistance...thanks
partition)
