So almost 10 years ago I bought this set: http://www.sony.co.uk/support/en/product/ht-ddw870
There is absolutely nothing wrong with it, and it gets used almost every day. The audio quality isn't perfect, but it's good enough for me. The only reason I would like to replace it, is support for modern codecs, more specifically DD+.
I'm using the Windows 8 app for Netflix, and it provides surround via DD+ but not the older DD.
I'm looking for an amp that will hopefully be compatible with my current active sub and satellite speakers. I would only replace the speakers if I really needed to. I also don't need the best, just something midway.
Any suggestions?
Any suggestions?
