Telkom help line is useless and I'm dumb ..plse help!
Presently using my dial up modem for this contact
Connected the CONEXANT USB modem.(Full Rate ANSI T1.413Issue 2 ITU G992(Glite) Single pentium3pc,one telephone line ADSL connection to TELKOM192 confirmed by telkom technician using his modem and laptop. I have correct username & password.
When I connect the telephone line to the modem The icon in status bar depicts a Conexant access runner ADSL which states its connected. Always shows bytes sent but NO bytes recieved.
When I installed hardware I was asked to choose a WAN or LAN connection!
Ive tried both with no success.
Using the LAN or HIGH SPEED CONNECTION I am told I am firewalled connected yet Still no bytes arwe recieved and no contact with internet achieved.
There is a repair option that has not helped after clicked except to say I should contact administrator.
On the icon shown as the standard blue pc faces as the Local Area connection6 it states Im connected.
When I chose the WAN connection I was asked for username and password which obviously makes me presume this is the right option but the reply is that the remote computor did not respond ...thus I am yet to be connected here.
I have installed the drivers , uninstalled the entire system reinstalled using both options yet still cannot connect.
The settings options states point to point protocol over ethernet PPPoE is been used with no other option available.
The connection uses : the standard list of options such as internet protocol(TCP/IP) Client service for Microsoft Networks , Client service for Netware etc etc some aere ticked some not with options to install and uninstall.
I rekon the problem could be here!....!!??
So as anybody with that basic knowledge or experience that I don't have will see I am sitting with too many permutations of obtaining a connection.
Is there is short and simple method in gaing a connection and As I assume there is could you either give a step by step procedure or if this is too detailed refer me to a site where specific help might be available.
QWell Here I sit in anticipation
Thank you in advance for any help tendered!!
