Help required
ALP
South Africa.
Good morning, It is a long time since I posted any thing on this forum.Mostly since I still do no have reception in my area, and Sentech is quiet.
But for now I need some help. I use my modem for connection from work with a laptop. I need to re-install the modem software and drivers but seem to have misplaced my installation disc.
If any one have any Idea how I can get hold of such a disc I will apreciate it.
If someone could lend it to me for an hour or two, or copy it on to my 'flash disc', it will be nice.
I live near the Kentucy on Ondekers road.
THANKS
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Rhino</i>
<br />Make and Model?
Save a horney friend........
Durban Mal Park(36) 53% sig 128k
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I understood it to be his IPW modem, which doesn't work at home but is used at work
Sorry, with this beeing the MyWireless forum, I assumed that everyone would relise that this is the drivers etc. that I requre.
Ta
You can download the installation stuff (dialer and drivers) from http://www.netvigator.co.uk/customer_services/installation.htm (20MB).
JAS, this worked fine... I cannot use the dialer supplied, but the drivers work fine.
I then user 'mysignal' from ProAsm and this all works fine.
Thanks for the help
This could be a good entry for the FAQs
The two newer dialer files in that version must be expecting some new feature that is in the 5.x firmware, and not in the 4.x firmware (possibly an AT command to get the info for the signal quality display). If you like I can easily email the older versions of these files to you (email me off-forum), and then the dialer should work. BTW: I have not upgraded to 5.x firmware.
