Help - setting up a VPN to work
Darth Garth
Got a Netgear DG834 and using the Cisco VPN client 4.05 on XP SP2 using IPSec/UDP.
Opened up UDP ports 500 and 4500 on the Netgear and XP firewall.
I get a "DEL_REASON_PEER_NOT_RESPONDING" from the VPN client.
The network dept gave me Group Authentication so there is no certficates and all that stuff required.
I am the first one using VPN so myself and the network techie are both learning.
I can see the concentrator on the net ... a Cisco 3000 afaik.
Any ideas folks ???.
I have learned that when you connect to the VPN, after authentication it actually connects back to you, so you need to make sure that you have a rule allowing port 500 (UPD) incomming from your VPN server to your machine. I am not sure if this is your problem though, cause your error massage sounds like a remote problem.
