MightyMuffinMan
Ok here's the problem.
I have 2 xboxes and each one is connected to a router with wireless enabled.
One router is connected to a computer and ICS (internet connection sharing) is used to access xbox Live.
The other Xbox connects directly to internet via the 2nd router.
I somehow need to connect the 2 routers wireless connections. Note a wired connection is not possible.
I don't need xbox live while using system link.
Basically : Xbox ----> Router-----> wireless <-----Router<----xbox
Here's a plagirised picture :http://img696.imageshack.us/img696/2337/syslinking.jpg
