Hi,
Need some help. I am sure it probably easy to do, but i am having a problem doing it.
1. I have a server on my LAN that is also connectible via the net.
2. It has an application running that is updated from remote sites. (The necesarry ports etc are open)
3. It is connected via a neotel fibre line, which has a fixed IP address. Lets say its 100.100.100.100
4. I have my internal IP address for it as 192.168.0.141
Now, lets say i want to update my application, but instead of sitting at a remote site, i am sitting here at the office. Currently, my app is hard-coded and will only updated to the public IP address of 100.100.100.100.
The only way i can update my app is to have it connected via the Net. So effectively, its using my ADSL line to connect to my fibre app. Hope this makes sense.
How can i create a network path on my ADSL router to say.. IF you see the address 100.100.100.100:8002, re-direct this 192.168.0.141:8002.
Please help. Its driving me mad, and updating via the Net takes 4 hours. Locally it take 10 mins.
Roddy
Roddy
