Help To many routers
Talen3
A slice of heavan thats been forgotin and thats wh
OK i have been searching for about 2 hours on routers and every time i find a good router and think its the one then, "oops,:eek: whats this a better one." so after 2 hours all i have gotten is a headache.:confused: I have been hearing grate things bout this billion routers and just want to know from thows of you that have one.
Can you host say a warcraft3 game then have someone that is one your network (behind the same NAT) Join that same game you created (not in bridge mode) and can you have bridge mode and normal DHCP routing running off the router.
And If any one know of demon of a router let me know so i can look at it and ponder some more.
Thank you
OK ppl i got the billion 7300G. Every thing was very easy and nothing is giving problems i just wanna know must i do the firm wear or must i just leave it.
Ow and you can host and join behind the same nat.YAY.:D. The Port forwarding was a dream all you do is find the mac address that the router gives to you (DHCP Table) then you give that mac addy a ip and everytime your comp boots it will be given that ip (Static ARP).
Then you just go to port Forwarding thing (Virtual Server) open the port put the ip of the pc for the port wam.
Ok my old D-link router made this realy hard.
One more Q how do i know if the firewall is on?
Hey bro, there should be a firewall option ;) Just check thoroughly .
My advice would be to contact BillionTech, here's the link for his username.
http://mybroadband.co.za/vb/member.php?u=8290
He's the Billion representative on myadsl, chat with him about all your router questions and woe's, I had his email address, but must of lost it ;)
