Help! Why can't I install Kali on a USB-C Drive?
foozball3000
Kyalami
I have a USB-C Flash Drive (32GB) that I'd like to install my Kali Instance to, so that I don't have to run a virtual machine every time.
The idea is to run it similar to being hot-swappable. Plug in the drive, reboot into the Kali OS and do my work that way.
Speed wise with USB-C, it should be more than fast enough to run it as a HDD.
But I cannot install it that way.
At first I thought 32GB is not big enough, but it seems that it's more than enough. I also tried this with Ubuntu which is much smaller, also no luck.
There is an option to create a live boot drive that you can write to its memory, but I've tried a lot of tutorials for that on both a Kali and an Ubuntu instance, they never worked. No idea why.
Shouldn't it be as simple as just installing it like you would with a 2nd HDD?
Then just choose from the PC's boot menu to use the USB drive instead of the GRUB?
Maybe this?
I assume you're trying to run Kali as a window within Windows by leveraging WSL?
If not then this:
Other than this, no clue.
You want to run Kali from USB and plug that USB in any PC/laptop and boot from it? But by the sounds of it you just going to plug it in your machine.
With encryption
Just a plain live USB installer which you can boot from.
@foozball3000
I've done it many times with Linux Mint.
What you need is 2x USB.
One to boot Kali Live and the other to which you will install.
Then, set PC/Laptop boot order to USB and then regular OS. Regular OS will always boot unless this (or other bootable) USB is present.
It worked so well for me that I could play Icewind Dale 2 (a Windows game) on my Linux Mint stick without any issues.
It is handy to have because you can pick up many nasty things in IT by stocking your USB into their systems and then you boot into Linux and format the USB before using it again on Windows.
@foozball3000
You have excellent taste!
Great game. Ironically I couldn't get it to work on Windows for some benign reason at the time (working since) so I tried it on Linux, even got 16:9 mod working.
What you are looking for is to add persistence to your live USB image, that will allow you to make changes etc that stick and use it like a normal OS.
I just want to point out that while persistence isn't what you describe above, the end result is the same, a bootable Kali where you can install software, save files etc that remain after rebooting the OS, just like it was an installed OS on the USB.
I might have to. We tried various iterations yesterday and all of them failed.
It might just be my terrible laptop (thanks ASUS).
The last time I tried setting up a persistence instance, it didn't work. But I'll try again during the week sometime
what you can do is use another PC to get it onto your flash then plug it into your laptop and see if you can boot into it. Laptops like ASUS USB type C isn't true type C I had the same situation. I think it is sharing the USB 3.0 controller. Easy to see actually if it doesn't have the little lighting logo next to its type C chances are it is not true type C
That is plain incorrect, there is no such thing as "true" and "not true" usb c.
The usb type C connector is the physical connector for the form factor, underlying it is support for different protocols namely USB and thunderbolt. The lightning bolt marker indicates the port supports the thunderbolt protocol.
yumi exfat version allows booting of multiple OS's.
I have a 64Gb USB-stick with 5 Linux distro's and a windows 10 installation.
Right then please plug a GPU into one and then the other and see how that goes for you
