Good day. I have a toyota tazz 2e. It originally came with a 4 speed manual but i opted for a 5 speed from a toyota runx. The box fits perfectly but the starter had to be modified to fit as it only bolts in with the top bolt. Over time the starter moves out of place which the car not start and you have to find the sweet spot and tighten it with the strength of Samson. I would like to know, are the bell housings interchangeable? Can i use the normal 2e 4 spd or 5spd bell housing with the box of the runx?
What is the main difference between a 2e and 3e engine? Pros and cons of the 3e over the 2e.
Thanks in advance
Thanks in advance
