Hi Guys.
I'm having a problem with the internet.
I'm running 3 PC's on a domain with another PC as the server, and a stand alone PC that isn't on the domain.
My problem is that 2 of the 3 PC's on the domain can't do anything on the internet ... if I ping co.za nothing happens, however I can use Skype. Can't even check e-mails
On the server PC the internet works perfectly. On the stand alone PC, the internet doesn't work either except for skype.
All of the above PC's are connected via a 24 port unmanaged switch to a Dlink 2500U modem.
I have 1 PC on the domain, where the internet does work connecting wirelessly to a Dlink 2100AP, which is connected to the 24 port switch.
Yesterday everything was working perfectly, and this morning all the problems started.
Does anyone here have an idea of what the problem might be?
Regards
Itai
Regards
Itai
