Help with Billion BiPac 7402GXL
gifs
I bought one of these 3G/ADSL routers with the intention of only using it as a 3G router as I don't have ADSL.
I set up everything with 3G as the default WAN connection. The wireless network was set up and both my PC and PS3 can connect to the router.
When a router has established a 3G connection, my PS3 can access the internet, no problems. But on my PC I can't seem to connect to the internet.
What do my connection settings need to be on my PC? On the PS3 I just followed the automatic setup and everything was fine.
I tried firefox and IE. Usually when connecting wirelessly to a router you don't need to have any special settings or am I missing something?
Check the IP settings on your PC.
If the PS3 can go on the internet then your router is fine.
Can you ping any websites from your PC?
just put your IP settings on obtain automatically
On the PC youre Ip settings need to be as follow:
Example Router:192.168.1.254
Ip address: 192.168.1.XX
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.254
DNS server: 192.168.1.254/ or Windows Server IP / Static DNS
If you are using a proxy server in firefox/IE then the Internet Connection should not work
If DHCP is enabled and PC is set to obtain Ip automaticly then all the settings should be imported.
