Hey Guys
Ok so i downloaded a couple of themes for my Blackberry 8520 Curve. Some were .alx/.cod files which can easily be installed via desktop manager but some of the others were .jad files. Ok so there is a readme that comes with the skin and it says the following
Now im assuming that i have to use the Roxio media manager that came with the phone software, but, how? i cant seem to install the files on the phone from within Roxio media manager.
Does anyone know how to install jad and jar files on a Blackberry?
RuDz
1. Copy all the files (all .cod .jad and/or .jar) onto your BlackBerry's memory card or internal memory
2. Open the media manager and click the menu button
3. Then select explore and find the files you copied
4. You then click on the .JAR or .JAD file and you will be shown the installation prompt just like you would if you installed the application OTA
RuDz
