Help with car audio system?
dayav07
Durban
Hi
I am busy on a small project.I put this in the motoring section because I am using car parts. I am making a speaker system (for home use) with 2 x Pioneer 120w three ways, a 400w pc power supply and a 300w (2x150w) amplifier. I wanted to add a subwoofer. found this one:
http://www.autostyle.co.za/starsound-sub-8-300w.html
Will a 300w 2 channel amp handle it? If not, what sub woofer can I get that my amp/psu can handle?
Don't know to much of this stuff, but I think your power supply is too weak. I will go for a decent power supply. something that go give 7 amps at least. I will take a old battery charger and smooth it's output.
Get atleast a 600va transformer that can put out a constant 15A at 12v and you should be fine powerwise.
