Help with choosing a transistor
Messugga
Pretoria
Hey guys
Now, I used to know how to do this, but I'm kinda rusty.
I've been tasked to build a circuit to switch LEDs on and off, by making use of transistors. Now, the problem comes in with choosing which transistor to use. I have a maximum of 15mA to actually switch the transistor with, but I'd like to keep it <10mA.
Can anyone help me out with a circuit maybe or at least tell me which transistor I should be looking at?
Cheers
Any general purpose small signal transistor should do the trick. E.g BC109, BC547
There are lots of circuits on the net to flash leds. Look for multivibrator/oscillator circuits. You could can even get a led that flashes on it's own, no circuit required. Also try Yebo Electronics for kits.
Flashing LEDs is an option, although you could try using a 555 timer to give the LED a pulse. It's a very easy method of flashing LEDs...
Yes, IC's would make many things easier. But I think the OP was specifically asking about using transistors to do the flashing. That's why I did not mention IC's. Maybe he is doing a "back to basics" course?:)
Could be. I'm not always fond of transistors because they have a tendency to um.... crash out on me, but will take a lookie for you.
well, thing is, the LEDs need to be controlled by a microcontroller, so just flashing them's not really quite what I want to do. Thanks for the suggestions though, much appreciated!
I built a timer circuit with a PIC microcontroller and some 7-segment displays and I used BC547's to drive the displays. Worked like a charm. Most of the transistors I had in my junk box from things that I cannibalised.
