help with d-link 2500-U router
Barney1212
hey all
i just got this router for the adsl line just been installed in my digs in pta.... wen the telkom guy came and finished we hooked it up and ran fine... but nw i took it to jhb so i could get mweb to configure it and test it it would not boot... the lan led stays green and power led does not come on or breifly goes red then off..
plz help i really need internet asap and can not wait for an rma to happen
I'm not exactly sure what the cause is here, but I'd guess that a reset might help...
Perform a reset to factory defaults, like explained here: http://www.modem-help.co.uk/D-Link/DSL-2500U-BRU-C-ADSL2--Modem-Router.html?info=1
You should then also configure your IP address such that it is on the same subnet as 192.168.1.x, eg. IP address = 192.168.1.2, subnet mask = 255.255.255.0
If you can't access the router's web interface on 192.168.1.1 then, then you should get it RMA'd.
I have the 4 port version of that router, the 2540U, and according to the manual, if the Power light (far left) goes red, then there is a 'Failure or Device Malfunction'. You can try reset it like Pada says, but your router may have bought it.
These routers cost R200 new, I'd rather just buy a new one. Less hassle IMHO.
Are any leds on at all?
Remember it's probably locked to one Dslam in the exchange. Ring Mweb and tell them you moved
