If WAN is disconnected, then WAN is not being used, but rather something else.
I dont know Linkhub72 but most routers will have dns settings on the LAN settings or Advanced settings.
My thoughts too. It's a WiFi router and I have access via a simcard but find it strange that the WAN is disconnected. I've been through every menu item and it can't be changed anywhere else. My only option is to do it on the adapter settings in the OS for each deviceMy concern would be that Vodacom have tweaked the software on the router, and trying to change the DNS stuff makes it have a small hernia and disconnect.
