Help with DVD drive
mkl
hi guys, i burnt a tv clip to a DVD from my LG RH7624W DVD/HDD player. The DVD player reads the disc fine and the clip can be watched on tv through that LG device. But when i put the disc in my computer's DVD drive, it doesn't read, and that DVD drive icon turns out to "CD-Drive", with 0 byte used space and 0 byte free space. The disc is a Memorex DVD-R.
Anyone know what the problem is? will be appricated with ur help. thx in advance...:confused:
If you're running Windows XP and below maybe your ASPI drivers for your DVD drive
are not installed. You'll need to go here:
http://club.cdfreaks.com/f3/forceaspi-installation-guide-101614/
Download AspiCheck and check if those drivers are installed, if they are not
proceed with the instructions as above ( http://club.cdfreaks.com/f3/forceaspi-installation-guide-101614/ ).
You can also get www.isobuster.com to view UNFINISHED discs (unfinalised ones).
You may be able to extract whatever is available to your harddrive and
then burn that with a DVD burning program like Nero or one of the free open source
ones.
thanks very much PeterCH. i downloaded IsoBuster and it sorted out the problem.
