MeNeZ
- Jul 28, 2006
Hi,
Im hoping someone can help. I setup a home network and it was working fine. Then I wake up in the morning and its not working and I havent been able to get it working since.
Basically I have an ADSL modem and a 5 port switch. Both are D-Link.
I have one cable (straight) going from my pc into the hub.
One from the modem into the hub and then my parents pc is also going into the hub.
Like I said, it was working perfectly. My parents could browse the net and I didnt change anything so I have no idea why it stopped working. I plugged the network cable into every port and tried with every combination. Last time, as I plugged the cable in to the hub it picked up the network straight away.
Do you think it could be the cable? Maybe my switch isnt switching anymore?? I dont have another cable or hub to test with tho...
