Hi guys
I need help with Inserting an Element into an Array, I'm using a book and when I code what's in the book called "Java Programming Made Easy - by Georgina Ramsamy" it comes up with many errors
this is what I have :
Please could someone explain to me what is wrong with this code and how to fix it and could you try to explain it in the simplest form
325i
Code:
import java.util.*;
public class Insert
int [] arr = new int[6];
Scanner kb = new Scanner (System.in);
public static void InsertElement()
System.out.println("Enter position to insert a value");
int pos = kb.nextInt();
System.out.println("Enter number to insert");
int num = kb.nextInt();
for(int i=arr.length -1; i>=pos;i--)
arr[i]= array[i-1];
arr[pos-1] = num;
for (int i=0;i<6;i++)
System.out.println(arr[i] +" ");
public static void main (String[]args)
for(int i=0;i<5;i++)
System.out.println("Enter value");
arr[i]=kb.nextInt();
InsertElement();
325i
