Help with monitoring internet bandwidth usage while using RouteSentry
offduties
Hi guys
I've got 4 PC's connected to a Telkom router, each PC has got RouteSentry setup. Is there anyway for me to monitor everyone's usage from my PC?? Because someone has been abusing the international bandwidth :mad:
Or is there anyway for me to check each person's i.p thats connected to the international account? because on my isp's usage stats page, it lists the individual i.p's and their usage.
Regards
Easiest way would be to give everybody their own International and Local Only accounts to use. Or, just their own International Accounts, local ones are cheap enough to not have to worry too much about "abuse".
Otherwise ...
The source code for RouteSentry is available, and you could probably save the assigned ip addresses to a text file for retrieval later.
Hey thanks for the reply, the thing is we are all students and we dont really need more than 3 gigs per month, so getting our own International accounts will be a bit of a waste.
I am too much of n00b to checkout the source code for RouteSentry :P , since I've only done some simple Java and C, but that is a GREAT idea if I could get everyone's assigned ip add and compare them to the usage, are there any off the shelf program that does that???
