Hi guys,
I'm in some serious need of help with my Proliant N40L.
I installed windows 8 using the original hardware (incl. 2gb ram) plus a Nvida GT610 and had a perfectly running server. When when I decided to upgrade the ram to 8 gb (2x Kingston KVR1333D3N9/4G) I got a dpc_watchdog_violation error. I've tried the following with no success:
I've checked the minidump file and it's listing APCI.sys as the drive that failed (I'm too much of a noob to know what to do with this info)
I've gone back to my 2gb ram and the system runs perfectly. I've checked that the Kingston ram is compatible with the system so that can't be the problem. I've also tried some cheap Apacer ram and that also failed.
I'm all out of ideas but I seriously need a ram upgrade; any help would be seriously appreciated.
- Flashing the bios
- Removing the graphics card
- using only one ram slot (interchanged between the two)
- reinstalling windows with new ram installed (this failed at 77% on initialising devices) - Had to then reinstall with my 2gb ram
