Hi guys,
Ok so I bought a new motherboard, CPU, RAM and PSU from Prophecy.
I built the PC and put in my graphics card and HDD's from my old PC. Now when I turn it on, all seems to be fine but the screen doesn't seem to be picking up any signal. I assumed it was graphics card so I removed that and plugged the screen into the motherboard graphics to see if that would work, sadly no. The graphics card was working perfectly in the old PC.
Now my question is, which component could be causing the problem? I have tried a different screen on the old graphics card and motherboard graphics port but neither worked. PSU seems to be working fine, PC boots and everything, no beeps to indicate error from the motherboard. Any solutions or tests I could run to see where the problem lies?
Thank you very much for all your help, and if you need any more info I'll provide as much as i can
