My setup is as follows
HP Micro server
Old Setup
(C\) - 250GB - OS installed (downloads are on this drive until processed)
Script is run to process and move files
(H\)- 2TB Ext - All content is moved from C\ to their folders and sub folders (Movies - Tv Shows etc)
So last week I ran out of space on (H\) so I bought an Internal 3TB....this is where all my problems started
Installed the drive etc but now when setting up Sickbeard how do you make it scan 2 different drive locations for series?
As drive (H\) is full, I copied the TV shows folder with subfolders (excl content) to the new drive (D\) and changed the relevant settings for all new episodes to go to this drive.
Also manually added a nzb and now I see that the script no longer works
Now all my shows don't download any more and sickbeard obiously shows that the old episodes are skipped or missing.
Also get this error on Sickbeard - ERROR SEARCHQUEUE-RSS-SEARCH :: Invalid SAB host, check your config: nonnumeric port: ''
I use NextGenNews as the provider
New setup
Script no longer works
(H\)- 2TB Ext - contains all old downloaded series and movies (Movies - Tv Shows etc)
(D\)- 2 TB - New Episodes
(E\) - 756GB - Moved all the movies from (H\) to this drive
The 3TB I bought is split into (D\) 2TB and the extend partition is (E\) 756GB
Can someone help me out please.....i'm having withdrawal symptoms from no new episodes
HP Micro server
Old Setup
New setup
