Hi all. Im having the weirdest of problems in a CAT lab at a school.
The users cant log in and get the message "domain xxxxxx is not available", but any user with administrative rights can log in.
When i checked the pc`s i found that the NIC led`s are not lit on pc`s in question. Can this be the problem? I checked the cables with a tester and it works. (from the wall bow to the pc - flylead)
How can i check the connection between the wallbox and the switch / hub to see if that is causing the problem?
There are 30 pc`s in the lab, all with xp pro and a server with server 2003.
