Help with SQL in Crystal Reports 2011
G_Auto
Good day
Could anyone please help us if possible. We are struggling with one section of our SQL in Crystal Reports 2011.
We are adding in commands into Crystal Reports to populate our custom report with commands such as:
Code:
SELECT TOP(5)
Name, RecordTime
FROM
CDBPoint JOIN CDBHistoric ON (CDBPoint.Id = CDBHistoric.Id)
WHERE
CDBPoint.Name LIKE 'M10%'
which gives us the result:
Code:
Row  | Name          | RecordTime
   0 | M10 Available | 19/03/2013 13:54:42.679
   1 | M10 Available | 19/03/2013 13:56:58.479
   2 | M10 Available | 19/03/2013 13:57:35.031
   3 | M10 Available | 19/03/2013 13:58:54.335
   4 | M10 Available | 19/03/2013 14:01:22.910
So that part of it works fine. But now we want to add onto the WHERE such that we only get results between a certain time on a certain date and are not able to get the correct syntax.
Hopefully somebody is able to give some insight into our problem.
Thanks in advance
Something like:
Code:
SELECT TOP(5)
Name, RecordTime
FROM
WHERE
(CDBPoint.Name LIKE 'M10%')
AND
(CDBHistoric.RecordTime BETWEEN time1 AND time2)
Where time1 and time2 are your time parameters.
Hi. Thanks for the reply. Unfortunately that was unsuccessful as well. It gave us the error:
Code:
SQL Command As Typed:
SELECT TOP(5)
Name, RecordTime
FROM
WHERE
AND
(CDBHistoric.RecordTime BETWEEN '19/03/2013 13:54:42.679' AND '19/03/2013 14:01:22.910')
*** Prepare failed - Query error. ***
*** Invalid operand ***
Code:
SELECT TOP(5)
Name, RecordTime
FROM
WHERE
AND
What happens if you put only this after the AND
CDBHistoric.RecordTime > '19/03/2013 13:54:42.679'
Hi
Unfortunately the error I get with that is:
Code:
SELECT TOP(5)
Name, RecordTime
FROM
WHERE
AND
(CDBHistoric.RecordTime > '19/03/2013 13:54:42.679')
*** Greater than operation '>' cannot be used with Timestamp and String. ***
The error message explains it. Either your parameter is a string and not datetime field or your db field is a string and not datetime.
So either change it so both are the same data type or use a conversion method to convert to datetime the value that is a string.
Yes we saw that and have tried many conversion methods without success. We are looking for the correct syntax to any solution. All our solutions havn't worked mainly due to syntax.
Can you show the table structure of cbhistoric here?
Is recordtime the string or is the parameter the string? the conversion method will depend what database you have on the backend
It looks to me like your RDBMS might store the datatime field in a different format to the date format you are using. Might be something like DDMMYYYY HH:MM:SS.XXX or YYYYMMDD HH:MM:SS.XXX.
This makes sense, but op not posting table structure.
I'm going to make the rash assumption that whoever designed the database probably didn't use a string datatype for the datetime field which probably means that the date format being used in the query is not the one you need (and is being treated as a string.)
I had a similar problem a while ago with querying our ERP system (SQL Server backend.) The date format in the application was neatly formatted in an easily readable manner like DD/MM/YYYY but the actual data in the field was stored in a format like YYYYMMDD HH:MM:SS
Queries only worked if you used the SQL table format
Thanks for all the help. We have managed to get the correct syntax for our SQL. We thought we'd share our solution as reference for anybody else.
We are using Crystal Reports 2011 with a ClearSCADA ODBC Database.
Code:
SELECT TOP(5)
Name, RecordTime
FROM
WHERE
AND
CDBHistoric.RecordTime >= TIMESTAMP ('2013-03-19 13:57:10')
AND
CDBHistoric.RecordTime <= TIMESTAMP ('2013-03-19 14:01:10')
It accepts that syntax and now we can use it to get our history values from any time. Eg:
Code:
SELECT TOP(5)
Name, RecordTime
FROM
WHERE
AND
CDBHistoric.RecordTime <= (CURRENT_TIMESTAMP - INTERVAL '5' MINUTE)
or any combination of that.
Hope that can maybe help somebody else one day in the future. Thanks again for all your help.
Cheers
